Hi ,
 I was using 10.1 server, expect the same for 10.2.
Thanks for the suggestions, however I was attempting this with a Windows Mobile Application, and not using the Windows WPF framework, so that code wouldn't work here.
This has to be available from the client side so that we don't force our users to log in to a service unless it is secured. Thus using the Admin tools is not an option.
A lot of strange errors found poking around the services with different urls, however settled on trying to hit the service using the WebRequest.GetResponse() , and using the ResponseUri property to check for a redirect to a login service.
thanks...glenn
