How do I add checkboxes to geoform on ArcGIS Server?
9766
14
12-01-2014 08:27 AM
BrandonKeinath1
How do I add checkboxes to a geoform we have hosted on our ArcGIS Server?  The fields have a yes/no domain applied but I'm not sure if that is correct or not.  Is there specific code I need to add to the configuration files?  If so which ones?
Best,
Brandon
SmittySmith
Yeah, this would be a great option to have.  I emailed some of the esri staff about this.
GeorgeKipp2
There is an option to use check boxes instead of dropdowns in the geoform configuration menu. When using the geoform builder, on the "Fields" option (number 5), click on the cog icon next to it.
Then select "Display As" and choose radio button. You can set up your domains to have a yes/no/all coded values.
Hope this helps.
AurelieShapiro
I only see select menu and filter select? How can I get the Radio Button option?
deleted-user-Sh7q9fbKLpEv
Hi aurelies‌,
The only way to access the Radio Button option in the form field's settings is to ensure there's a domain associated with the field.
-Jacqueline
AurelieShapiro
There is a domain. I can make a menu, but for some reason in this domain, it does not show an option for radio button.
The choices are select menu and filter select …
It must be something with my domain but I can’t figure it out – it was made the same way as the other domains in my gdb…
Von: Jacqueline Kovarik
Gesendet: Mittwoch, 18. April 2018 16:19
An: Shapiro, Aurelie
Betreff: You have been mentioned by Jacqueline Kovarik in Re: How do I add checkboxes to geoform on ArcGIS Server? in GeoNet
GeoNet <https://community.esri.com/?et=notification.mention>
by Jacqueline Kovarik<https://community.esri.com/people/jkovarik@co.carver.mn.us_carver?et=notification.mention> in Re: How do I add checkboxes to geoform on ArcGIS Server? in GeoNet - View Jacqueline Kovarik's reference to you<https://community.esri.com/message/765028-re-how-do-i-add-checkboxes-to-geoform-on-arcgis-server?commentID=765028&et=notification.mention#comment-765028>
