How can I check if the Geometry Service is activated in my map service
232
10-20-2025 10:18 AM
SanchezNuñez
Good afternoon
How can I check if the Geometry Service is activated in my map service?
CodyPatterson
MVP Regular Contributor
Hey @SanchezNuñez
If you mean the Geometry Service itself, it can be found in the ArcGIS Server Manager here under Utilities in the Services > Manage Services section:
To properly perform the query actions it's speaking of, as long as an uploaded service has the Feature capability enabled you will be able to select, analyze, query and the sort, Map Image Layers don't have that functionality. Also the Operations Allowed section:
Cody
Priya_Das
Hi @SanchezNuñez
You must update the geometry utility service for your ArcGIS Enterprise deployment to use the preconfigured geometry service of the hosting server or one of your federated servers.
Documentation: https://enterprise.arcgis.com/en/portal/11.4/administer/windows/about-utility-services.htm#ESRI_SECT....
Refer this documentation: https://enterprise.arcgis.com/en/portal/11.5/administer/windows/configure-services.htm#ESRI_SECTION2...
