I am trying to use a webadaptor instance on Linux to connect to ArcServer instance running in Windows and I get a generic error that my login is no good. The problem is that my login info is good as I can sign into ArcServer manager from my Linux box. The esri help on the subject says it should work. Additionally, if i use the Webadaptor Java version for windows (Windows tomcat 8.5.23) - it connects easy peasy, 1, 2, 3 with default settings.
My question is:
Has anyone out there successfully connected a Linux Web adaptor to a Windows ArcServer instance? If so, did you have to do anything special to get it to work?
My set up:
(Both machines are Hyper-V virtual machines on the same physical server)
Web Adaptor
- Hyper V Generation 1 machine
- Centos7
- esri Web Adaptor 10.4.1 for Linux
- Tomcat 8.5.23, port 8080
- Java open sdk 1.8.x
- port 8080 is open
ArcServer instance
- Hyper V Generation 2 machine
- Windows 2012 R2
- ArcServer 10.4.1 Advanced
- Ports 6080 & 6443 are open
