Granting permissions to the ???ArcGIS Server Account??? user on data stored in client...
4388
6
02-07-2013 09:57 AM
by Anonymous User
Not applicable
Original User: Jamal432@gmail.com
Granting permissions to the �??ArcGIS Server Account�?� user on data stored in client machine,
As the ArcGIS server is installed on the server machine (named p2) then the account �??ArcGIS Server Account�?� user is created automatically on that machine.
While working on the client machine (named p1) and having the data stored on it then how to give permissions to the �??ArcGIS Server Account�?� user (which is a user on the server machine) knowing that the network type is �??home network�?� (no domain is set).
[ATTACH=CONFIG]21575[/ATTACH]
In this case, there is no way to grant the �??ArcGIS Server Account�?� user (which is a user on the server machine) permissions on the client machine
[ATTACH=CONFIG]21576[/ATTACH], [ATTACH=CONFIG]21577[/ATTACH]
How might this issue be resolved?
Thank you
Best
Jamal
by Anonymous User
Not applicable
Original User: rlwatson
There is a Windows trick that might work for you.  Simply create a local account on the client machine which has the exact same username and password as the account that the server will use to access the client.
JamalNUMAN
Legendary Contributor
Thank you Richard for the help,
Could you please elaborate a bit more regarding this issue?
�?� The screenshot below shown the map of user of a client machine
[ATTACH=CONFIG]21581[/ATTACH]
�?� The screenshot below shows the maps of users of the server machine (which includes the �??ArcGIS Server Account�?�)
[ATTACH=CONFIG]21582[/ATTACH]
�?� Do I need then to create a user on the client and server machine that has same credentials?
Best
Jamal
Jamal Numan
by Anonymous User
Not applicable
Try creating "ArcGIS Server Account" on the client with the same password that you used on the server.
JamalNUMAN
Many thanks Richard for the help,
�?� The �??ArcGIS Server Account�?� user is added to the client machine (p1) with the same password as the one on the server machine (p2)
[ATTACH=CONFIG]21625[/ATTACH]
�?� But the problem is still there
[ATTACH=CONFIG]21628[/ATTACH]
�?� Another folder which include other data is shared and permissions were given to the �??ArcGIS Server Account�?�
[ATTACH=CONFIG]21626[/ATTACH], [ATTACH=CONFIG]21627[/ATTACH]
�?� I tried to register this folder but I got the message �??the arcgis is not able to connect to the specified folder. Please, ensure the folder exists and has the appropriate permissions for the arcgis server to access it�?�
[ATTACH=CONFIG]21629[/ATTACH]
�?� I tried to register the same folder (after being copied and pasted to the D:\ partition of the server machine) and it has been SUCCESSFULLY registered
This emphasize that this issue is related to the relationship between the client machine (in which the arcgis sever is NOT installed) and the server machine (in which the arcgis sever is installed).
How such very tedious issue might be resolved?
Best
Jamal
Jamal Numan
by Anonymous User
Not applicable
If you want to share file based data then I think that the way to do it is to use UNC, e.g. \\machinename\Share, paths.  Everyone has to use the same UNC path and it is this path that must be registered with the server.
If that doesn't work then I'm out of suggestions:(
JamalNUMAN
Thank you Richard. I see if I can sort it out.
Best
Jamal
Jamal Numan
