GPService timeout
3049
10-27-2015 04:35 AM
manuelcastro
We have published a GPService in ArcGIS Server 10.3.1 to publish a map service from a mxd and then create a map cache and tiles based on this examples
http://server.arcgis.com/en/server/latest/administer/linux/example-publish-a-map-service-from-a-map-... and http://resources.arcgis.com/en/help/main/10.1/index.html#//00540000000p000000
The process is successfull when the time to complete the task takes little time, but when it´s quite long (about 48 hours) a timeout error is displayed and the process ends as "failed".
SEVERE     25/10/2015 17:42:18     Error getting job resource Error handling service request :Service startup timeout.
SEVERE     25/10/2015 17:40:45     Failed to construct instance of service 'publishAndCacheTiles.GPServer'. Service startup timeout.
We set the maximum time a client can use a service parameter to 604800 (1 week)
Is there any way to make the gpservice can run for a long period of time without timeout error?
Thanks in advance
Tags (3)
