Having an very odd issue, and running out of luck... any help would be appreciated as this is just a fun project on the side for school.
I am using Web App Builder (WAB) to call and run a geoprocessing service (async), and this is suppose to return the Results as a web map service. After logging to WAB, i run the service, and no results show up (fiddler console: Invalid Token)
which is very odd, because it runs the service no problem, just fails to use the token when adding the service.
If I am logged in, and I visit the Arcgis/rest/services folder, and re-run the tool, the results now show up.
I have installed and configured web adaptor, portal, federated server, you name it, everything runs smooth and dandy but this.
Any thoughts on how to configure this correctly, or if anyone else has had any issues with it?
I'm wondering if you need to set up a proxy, even if the service isn't secured. I know for a custom printing GP service, I had to reference a basically empty proxy file to get it to work.
