Generate access token with ArcGIS REST API in ArcGIS Enterprise 10.8.1
3362
03-15-2022 04:12 AM
andrei_ste
Hello everyone,
I would like to generate an access token with the ArcGIS REST API to access private content in ArcGIS Enterprise 10.8.1 either using the oauth2/token or generateToken endpoint. For both cases I managed to generate a token, but when I try to use them to access private services from the Portal I receive everytime an error with the code 498 and the message: Invalid Token.
Below I generate a token using oauth2 application credentials:
After that I try to use the token to get the information from the ArcGIS REST Services Directory main page from a service that is shared privately, as a json response and get the error 'Invalid Token':
Can someone help please or did someone had this issue before? I used the same request to access private content from ArcGIS Online and it worked.
andrei_ste
So I managed to create a valid token using the generateToken endpoint:
I was using client=ip or client=requestip instead of client=referer and this was generating a token that wasn't valid. Still having problems generating a token with oauth2, app login. Can someone please provide an example?
