Function to get next OBJECTID when inserting data into Oracle FC using SQL
4105
04-06-2023 07:34 AM
Bud
Legendary Contributor
Oracle:
I remember there being a SDE function for getting the next OBJECTID -- when inserting data into an Oracle FC using SQL. But unfortunately, I can't remember the function's name. And I can't find that section in the Esri documentation.
Does anyone remember what it's called or where I can find info in the docs?
(I'm aware that there are risks/things to consider when editing FC data using SQL. I'm just doing some testing in some fake data.)
Thanks.
Tags (3)
RyanUthoff
MVP Regular Contributor
RyanUthoff
I believe this is what you're looking for. https://desktop.arcgis.com/en/arcmap/latest/manage-data/using-sql-with-gdbs/workflow-using-sql-with-...
The SP is called i##_get-ids
Bud
Thanks.
Also: Editing nonversioned geodatabase data in Oracle using SQL
INSERT INTO eng2.streams (OBJECTID,NAME,SHAPE)
 VALUES (
  sde.gdb_util.next_rowid('ENG2', 'STREAMS'),
  'TRANQUIL',
  sde.ST_GEOMETRY('linestring (750 150, 750 750)', 4326)
