Failing to publish map services with feature classes and joined tables
2456
09-17-2014 06:30 AM
MehrshadNourani
New Contributor III
Greetings,
I receive an error when publishing map services to ArcGIS server 10.2.2, which include layers with joined tables. I am using ArcGIS 10.1 for desktop to publish these services. The error image is attached.  I would appreciate any comment that would help resolve this problem.
Thanks
Mehrshad
Message was edited by: Mehrshad Nourani
AnthonyGiles
Frequent Contributor II
The error you are receiving seems to be quite a generic one, often related to permissions that server has to the base data. Does your server account have access to the table that you have joined?
There are quite a few different instances where people have received the same error in this discussion:
https://community.esri.com/thread/58748?start=0&tstart=0
Not sure how much help it will be
Regards
Anthony
MehrshadNourani
New Contributor III
Anthony,
Thanks for your reply and sorry about the late reply!  Yes, I do have full access and permission on the server. My gdb is also registered with the server.  I don't have any issues publishing services to 10.1 server, only 10.2.2 that has these problems. The same issue appears when publishing from 10.2.2 desktop to 10.2.2 server.
Regards.
Mehrshad
