I have an ArcGIS Online to Portal collaboration using Portal 10.6. I would like to copy AGOLs feature layer(sync is enabled) to Portal as a copy. Here are the errors that I am receiving.
| WARNING | Item '088a9adf36024701b7cb96194307209a' received from participant was shared as a data copy but was added as a reference. | 2020-02-26T19:34:09,280 | Sharing | | | 219999 | 4041 |
| SEVERE | Failed to publish replica as a hosted feature service. | 2020-02-26T19:34:09,280 | Sharing | | | 219999 | 4041 |
What is the cause of this and what is the solution? I have un-shared the item and shared/synced again, but the issue remains.
