Extension with ArcMap Provider is ArcGIS Server 10.9.1
527
06-29-2023 06:29 AM
ADITYAKUMAR1
 I have 2 extension with I was using with ARcGIS Server 10.8. But now I have upgraded my server to 10.9.1 and replaced ArcGIS Pro with ArcMap. Since 10.9.1 doesnto support Arcmap runtime do we need to change this as well because while publishing I am not getting this features in capability section.
Is there a way to make it work?
Aditya kumar
JalesM
by Esri Contributor
ArcGIS Enterprise 10.9.1 DOES support the ArcMap runtime. Please see the blow here:
However, the next version, ArcGIS Enterprise 11.0, does NOT support the ArcMap runtime. So, you should be fine for now. 🙂
