Esri Licensing - Can Enterprise Viewer User Types Edit Features Of Secured Services of Unfederated ArcGIS?
646
05-08-2025 04:11 PM
JonSwoveland
This question is specifically about whether the following scenario would violate Esri's licensing.
Let's say an organization has a full ArcGIS Enterprise 11.3 setup (Portal, Server, Datastore), as well as standalone (unfederated) ArcGIS Server that uses built-in users and role permissions.
I know that feature services from the unfederated ArcGIS Server (UAGS) can be registered in Portal using stored credentials, shared like any other Portal item, and then made available to a web map.
In this scenario would viewer user-types be able to edit these feature services.
Another possible scenario is a custom application that allows users the ability to edit such services via a server-side process that handles the service requests uses stored credentials.
Would either or both of the above run afoul of Esri's licensing terms of service?
