Error with updating Enterprise Geodatabase with data from ArcGIS Online
954
8
02-28-2025 07:51 AM
TerryInniss
I collected data using field maps and I am trying to update the Enterprises database. I can see the data in the attribute table but the feature is not plotting on the map. I am using ArcGIS Pro and have Sql server geodatabase. I am using the Load command and fields in both what I am uploading and database match. Anyone else having this issue.
TerryInniss
I deleted the table and and recreated it and was able to add the data to the table in geodatabase. I was then able to see the data on the map.
George_Thompson
Esri Notable Contributor
Is the data versioned?
--- George T.
TerryInniss
Explain more. I am just exporting it from ArcGIS online and trying to load into the an existing table in the geodatabase so explain what you mean here.
George_Thompson
When you are loading the data into the SQL Server Geodatabase, you say that you can see the data in the table but does not show on the map.
Are you looking at the table in SQL Server or Pro?
--- George T.
TerryInniss
In ArcGIS Pro
George_Thompson
Ok, I wonder if there is an index / spatial extent issue. If you disconnect (close) Pro, then reopen is the feature showing on the map?
Is the feature showing anywhere on the map? If you zoom to it, what happens?
Try to rebuild the index, https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/modifying-a-spatial-index.h....
Is there data in the shape field?
If you copy out the feature class into a temp file geodatabase, is the feature there?
Can you provide any screenshots for reference?
--- George T.
TerryInniss
Ok, I wonder if there is an index / spatial extent issue. If you disconnect (close) Pro, then reopen is the feature showing on the map? No it is not showing
Is the feature showing anywhere on the map? If you zoom to it, what happens? When I try to zoom to any of the points nothing happens
Is there data in the shape field? Yes
If you copy out the feature class into a temp file geodatabase, is the feature there? When I add the same records to the file database, they show on the map
TerryInniss
George_Thompson
That is weird, but glad that you are able to now load data.
--- George T.
