Not sure if I'm asking this question in the right place. I am having an error opening arcmap on PC's I have not previously logged into before. Image is attached showing the error messages. Other people can log onto the same PC's and arcmap will work for them. What I've tried so far:
1. deleted Normal.mxd > makes no difference. The setup/config doesn't get that far in the process when I launch arcmap.
2. renamed the folder H:\data\arcmap\ but again the setup/config doesn't get far enough in the process before erroring out. referring to this folder:
