Q 1. Error in executing jobs on GeoAnalytics Server.
Q 2. Unable to insert data into SpatioTemporal big data store.
To explore capabilities of ArcGIS GeoAnalytics server we have configured following,
1. ArcGIS Enterprise (ArcGIS Server, Portal, web adaptor) - status working
2. ArcGIS SpatioTemporal data store (configured with Portal)
3. ArcGIS GeoAnalytics Server (federated with portal)
Total Three machines (1 for ArcGIS Enterprise, 1 for SpatioTemporal data store, 1 for ArcGIS GeoAnalytics Server)
Version of ArcGIS - 10.5.1
Our machine configurations are
OS - Windows server 2012
RAM - 16 GB
Core - 4
Hard Disk Size - 100GB
Applied patch for ArcGIS GeoAnalytics Server 10.5.1.
Ensured no firewall issues / firewall is switched off.
GeoAnalytics Server Configurations
Maximum allowed compute cores per job (CPU): 2
Maximum allowed memory per job per machine (GB): 4
Refereed documents
Set up ArcGIS GeoAnalytics Server—Portal for ArcGIS (10.5.x) | ArcGIS Enterprise
Following is the error log of GeoAnalytics Server
Error executing tool. AggregatePoints Job ID: j898c7cb232c645fd9806af7bfd56dec2 : {"messageCode":"BD_101057","message":"Unable to start distributed job. Please check your GeoAnalyticsTools service settings and ensure that there are enough resources available for the job to run."} {"messageCode":"BD_101031","message":"Job has been cancelled."} Failed to execute (AggregatePoints).
Following is the error log for SpatioTemporal data store
Job 'jaa0d6a1492c64686b2555f8460d6c74d' for tool 'CopyToDataStore' failed: Connect to <configured hostname>:9220 [<configured hostname>/ip addresss] failed: Connection timed out: connect. Connection timed out: connect.
Please suggest on above issues.
