Error 001359: Failed to connect to server : ArcGIS server 10.3.1
10882
10
07-31-2015 11:57 AM
LakshmananVenkatesan
Hi
I have installed ArcGIS Server 10.3.1 - am unable to publish the services. When i try publishing using Arcmap am getting Error 001359 Failed to connect to ArcGIS server. ArcGIS server configured to HTTP and HTTPS and uses Web adaptor. PublishingTools does not get started, it throws an error . I could able to connect to manager using HTTPS and view services etc,
Service failed to start
  1. System.PublishingTools.GPServer: com.esri.arcgis.discovery.servicelib.AGSException: java.lang.Exception: java.lang.Exception: The server was unable to access the URL 'https://myserver:6443/arcgis/services'. Please check your firewall and security settings. For more information, see the ArcGIS Server help topic Ports used by ArcGIS Server. You can access this topic in the table of contents by navigating to Administering ArcGIS for Server > Securing your ArcGIS Server site > Configuring a secure environment for ArcGIS Server.
ArcGIS server throws error "AGSAdminConnect FAILED."
When I configure HTTP authentiction, publishing service started. I have throughly investigated all data-configure and other config files could not find place a where call "https://myserver:6443/arcgis/services" is made?. Deleted site and recreated everything looks good.
I am not able to start the publishing service and publish any service. Any pointers is highly appreciated.
Javier_Pintos
Dear Anastasia,
Apologies for delay in response.
In Exceptions, I configure all internal DNS from my company with *, for example: *.mycompany.net ; *.anotherinternaldns.ad
I do this so that the requests to those internal domains do not go through the proxy.
Best Regards.
Javier
