Enterprise on Azure & AGOL Distributed collaboration - Error when I try to access a table of a feature layer hosted in Enterprise
1089
10-31-2024 09:23 AM
PanGIS
I set up an Enterprise instance in Azure.
Self signed certificate. (I am quite sure the issue is here, I am very unfamiliar with it, though)
I set up a distributed collaboration with AGOL and everything is ok. I see the group and the content.
But, if I try to access the layer I get an error: "There was an error"
What I need to configure in order to fix the things?
Thanks!
JakeSkinner
Esri Esteemed Contributor
Hi @PanGIS,
1.  What type of collaboration are you creating (i.e. Enterprise --> AGOL, AGOL --> Enterprise, or bi-directional)?
2.  When you set up the collaboration, did you specify to share the items as referenced or copies?
3.  What version of ArcGIS Enterprise are you running?
PanGIS
Hi @JakeSkinner
Thanks for your reply.
My current priority is to have real-time data of a referenced SQL database published on a service on Enterprise and available on AGOL.
I set up a bi-directional (but I can change it into Enterprise --> AGOL as this is what I need.
To clarify: the layer that I try to access is hosted in Enterprise and I am opening in AGOL.
Items are referenced
Enterprise 11.3
PanGIS
To add on this: the issue is half solved, the issue of yesterday is sorted (not sure how) but I have a new one.
Yesterday I switched off the Azure machines, this morning I put them on again and I could access the layers.
I am the owner of both distributed groups and the admin of organizations.
I added 2 new users in the AGOL group but they cannot see it same issue the item is visible but data isn't accessible.
Logged as one those accounts, If I refresh the item in AGOL, I get a login page.
But this AGOL account does not have an account in Enterprise.
