Ensuring Layers stays at Top
1067
12-15-2020 09:57 AM
cardiokan
Is there a possibility when the layer list is created and you then 'add data' that the new data does not go above the current data in the layer list.
Does anyone know if that is a possibility?
Thanks
ThomasJones1
Hello @cardiokan ,
If you are using the web map viewer you can reorder your layers after adding your item to the web map. Layers will always be displayed on top of a basemap and feature layers are always displayed on top of tile layers.
Portal for ArcGIS - Organize Layers
Thomas.
