Enable SPATIAL_VECTOR_ACCELERATION in Oracle databases
3046
7
07-07-2022 04:06 AM
Bud
Legendary Contributor
I've noticed that some organizations forget to enable SPATIAL_VECTOR_ACCELERATION in Oracle databases...now that Oracle Spatial is free.
Oracle Spatial Vector Acceleration: Flick the Switch
So for any of us who use SDO_GEOMETRY, we need to remember to enable that parameter — to make use of it's performance boosting functionality. (It's enabled by default in 21c+.)
I just thought I'd mention that...for those of us who were unaware.
Note:
I've asked the Oracle Spatial team if there's a way to check if SPATIAL_VECTOR_ACCELERATION is enabled (as a non-dba). But I haven't found a solution yet.
LaurensKusse_hhdelfland
We changed this setting to TRUE on one of our databases (Oracle 19c) that uses SDO_Geometry. We don't notice any change in performance.
Does anyone know a test to check the change in performance?
I tried spatial joins and al kinds of "Select by Location''-tasks, but they all take up the same time in a database with SPATIAL_VECTOR_ACCELERATION=True and a database with SPATIAL_VECTOR_ACCELERATION=False.
Bud
@LaurensKusse_hhdelfland You could ask on the Oracle forum. You might need to use a SPATIAL tag in your post to get the attention of the Spatial team.
Alternatively, you could ask on GIS Stack Exchange.
Bud
By the way, I think the spatial analysis done by Select By Location is performed by ArcObjects in your PC's RAM, not by the database. I had a post about this on GIS stack exchange, but can't find it.
Thank you!
I asked Esri support about this. They confirmed that Select By Location is done client-side.
But I still don't really know if this SPATIAL_VECTOR_ACCELERATION-setting improves anything related to Esri-products.
I just asked Esri support if they know if this might improve the performance of services. Or do you think that this is also handled client-side/service-side and not via the database?
Bud
Best guess is that only SQL queries that use spatial functions, and where the datatype is SDO_GEOMETRY, would make use of that setting; in other words, only spatial SQL queries that you have written yourself would use that setting. @MarceloMarques might have some insight.
Bud
@LaurensKusse_hhdelfland I would be interested in hearing Esri Support's response.
By the way, you might find this interesting: Intended use case for Select Layer by Location — Intersect (DBMS)?
MarceloMarques
This is correct, the Oracle SPATIAL_VECTOR_ACCELERATION parameter is only for Oracle Spatial SDO data type.
Only the Oracle SYSDBA will be able to make changes to the parameter.
To grant a non-SYSDBA user permission to view Oracle database parameters in Oracle 19c, you can grant them access to specific dynamic performance views. Here's a step-by-step guide:
Create a view: Create a view based on the dynamic performance views you want the user to access. For example, to grant access to V$PARAMETER:
CREATE VIEW my_parameter_view AS SELECT * FROM v$parameter;
Grant SELECT privilege: Grant the SELECT privilege on the view to the user:
GRANT SELECT ON my_parameter_view TO myuser;
This approach allows the user to query the view without needing SYSDBA privileges.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
