When I federated our portal install I entered the wrong url for the services. Is there a way to edit this with out un-federating the server?
Okay, so we restored the sever from a snapshot to a point before the error was made. Then federated again.
1) Log into the Sharing API as an Administrator through https://machine.domain.com:7443/arcgis/sharing/rest
2) In your account information page, there will be an Org ID property with a link to 0123456789ABCDEF. Click on that link
3) All the way at the bottom, click on Servers under the Child Resources section
4) Click on the Server ID link and then Update Server
5) Enter the new services URL and the existing Admin URL and click Update.
You'll then need to go through everyone's content and update any URLs to any services that are not hosted services
1) Go into a users content in the Sharing API, (https://machine.domain.com:7443/arcgis/sharing/rest/content/users/<user>/items/ for example)
2) Select a non-hosted service and at the bottom, select Update Item
3) Enter the new URL in the URL parameter box
You can use the Python API to traverse through each user and their content, find all non-hosted services and update the URLs if you want. You'll need to republish hosted services for the URL to update.
Manually edit the Portal's Federation with ArcGIS Server by going to the Portal Sharing Directory (/portal/sharing/rest) > Home > Portals > Self > Servers > Server ID > Update Server. 1. https://xyz/arcgis/sharing/rest2. Portals>Self>Servers3. Click on Server ID4. Corrected URL, reentered Admin URL (required)
I tried the above steps and shared a new service but it does not seem to be updating the service urls
That workflow doesn't update any existing services. You'll need to update the URLs using the Sharing API.
Thanks Jonathan. I understand that it would not fix services that already have been shared with portal. But when I share a new service from server manager to portal it should have the updated url, yes? Because it is still not working...
My coworker (who has a lot more knowledge of portal then me) feels that there is no way to recover from this situation, and we just need to spin up a new server and config.
Jonathan, Can you share more details about using the Sharing API to update? I believe I have made the same mistake and need to update the ArcGIS Server services url.
I don't mind republishing services once the change is made but i'm unclear as to where I would make this change. Can you add any details to how I would accomplish this?
This is great! Thank you. But, and you knew there would be a but.....
I think i'm uncovering my issue here slowly. There is no option for Servers?
So under https://machine.domain.com:7443/arcgis/sharing/rest/portals/0123456789ABCDEF you don't see Servers? This is what I see when I'm signed in as an Administrator:
Make sure whatever account you're using is an Administrator within the Portal.
ArcGIS Enterprise 11.4 now has better support for changing the URLs: Update the organization URL—Portal for ArcGIS | Documentation for ArcGIS Enterprise
Signed in members can post, follow updates, and more. New here? Register a free account.
