Does the geodatabase keep track of specific details for when editor tracking is enabled and disabled?
1128
02-11-2022 01:17 PM
BillFox
MVP Notable Contributor
I know you can look at the properties of the feature class in catalog to see if editor tracking is enabled or disabled. And look at the editor tracking user/date field values as needed.
Does the geodatabase keep track of when editor tracking is enabled and disabled so you can see the date-time stamp, user and workstation details when editor tracking is enabled and disabled on a feature class?
Example 1, On premise point feature class in an SQL Server geodatabase registered as versioned without edit to base.
Example 2, Similar scenario in AZURE
Example 3, Similar scenario in AGOL
Tags (1)
Scott_Tansley
MVP Regular Contributor
Have you considered the archiving option?  The time stamp of the modify can then guide you back to the archived edit to see the change?
Scott Tansley
https://www.linkedin.com/in/scotttansley/
