Do I have to republish all the map services after upgrading ArcServer from 10.0 to .2
1142
03-05-2014 12:06 PM
dancheng
I am just wondering do I need to republish all the map services if I upgrade ArcGIS Server 10.0 to 10.2.
Dan
WilliamCraft
That's correct.  Please mark the correct answer with the green check.
WilliamCraft
Here is the answer to your question:
Services are not automatically migrated from version 10.0 to later versions. The migration path for these services is to re-create them using the newer version.
Source: http://resources.arcgis.com/en/help/main/10.2/index.html#//0154000002p0000000
I'd recommend opening your 10.0 MXDs and performing a Save As to get them into a 10.2 MXD using a 10.2 ArcGIS Desktop client.  From there, you can re-publish them.  Make sure you register the data store(s) behind all of your MXDs with ArcGIS Server BEFORE publishing; otherwise server will attempt to make a copy of the data and ship it up to the server as local data.
dancheng
Thanks a lot. I have looked at the thread you sent. If it was from 10.1 to 10.2, I assume I do not need to republish everything ,right? since major changes occurred at 10.1.
Dan
WilliamCraft
