Datastore service starts and fails
821
05-18-2022 06:35 AM
MichaelGinzburg
Hello, the ArcGIS Datastore service suddenly start to fail. After restart it works about a minute and then fails again.
No antivirus.
Researching logs I found following error:
com.esri.arcgis.discovery.nodeagent.NodeAgentException: com.esri.arcgis.datastore.common.DataStoreException: Attempt to start data store machine on '' failed.. Extended error message: com.esri.arcgis.discovery.json.JSONException: A JSONObject text must begin with '{' at character 1 of
            at com.esri.arcgis.datastore.plugins.DataStoreManagerPlugin.start(DataStoreManagerPlugin.java:81)
            at com.esri.arcgis.discove…
What can be the source of this error?
Thanks!
Brian_Wilson
Honored Contributor
It looks like  a broken or missing JSON config file. Have you looked at the newest log files to see what they say? Edit -- yeah that's what you said already duh...
Try again -- is there any clue as to which file it's trying to open?
JohnKennedyTailteEireann
Hi - just wondering if you ever found a solution to this? We're having the same problem and can't figure it out. Thanks.
