Data Stores do not have a Portal URL
488
02-03-2023 08:15 AM
CameronMcKee1
New Contributor III
Our servers were recently restarted due to a power outage.  I have been performing a few checks to see if everything is working:
1. Web services that use data stores appear to be fine when viewed in a web map.
2. When validating data stores through Server Manager, the relational data store validates, but the tile cache does not.
3. When running server.datastores.validate_egdb on the relational data store I get the following error which has never come up before: Unauthorized access. Token not found. You can generate a token using the 'generateToken' operation.
4. When running descibedatastore.bat I noticed that the "Portal for ArcGIS URL" is blank, which seems odd.  It was definitely set before.
Given that services appear to be working, I'm not sure how serious of an issue this is.  However, if you can let me know the best way to update the URL, it would be appreciated.
Cameron
Tags (3)
