Custom Print Service Failing
17941
29
07-07-2022 03:27 PM
LeviRoberts
We are using ArcGIS Enterprise 9.1 and are trying to publish custom printing services from ArcPro 3.0.
We have followed very closely to the two resources listed below. And we are experiencing inconsistent results.
Share custom layouts for printing from ArcGIS Pro
Enabling High-Quality Printing in Web Applications
The error we are now consistenly recieving is "Error executing tool. Export Web Map : Missing or invalid layout template file. Failed to execute (Export Web Map)."
We have tried a variety of layouts, from including titles and overview maps like in the video, to including nothing but the WEBMAP_MAP_FRAME. It will print the "MAP ONLY" option, but when we try printing any custom layouts it will fail.
The default printing service works fine, and the custom services we built in ArcMap are still working, but anything in Pro is failing us.
In this session, techniques will be described and demonstrated for exporting high quality maps from web applications. We will cover creating printed PDF documents, printing to scale, leveraging ArcGIS Pro layouts, displaying all content on the map, modifying the map content during the export ...
Teresa_Blader
Is this true for stand alone arcgis server, or just federated enterprises? Sometimes the language is confusing. We are on ArcGIS 10.7.1 with Pro 3.0 and ran into this error. So, if we go back to Pro 2.9, hypothetically it'll work with 10.7.1?
Teresa Blader
Olmsted County GIS
GIS Analyst - GIS Solutions
JeffLegato1
Yes, that's what I had to do. Use an older version of pro.
Teresa_Blader
@TanuHoque will this compatibility issue apply to Pro 3+ or just 3.0
My colleague wonders if this issue will go away if we upgrade to 3.0.3 while still on 10.7.1
Teresa Blader
Olmsted County GIS
TanuHoque
hi
Sorry for the delay replying back on this.
Unfortunately, it won't go away. Technically it doesn't really matter where you publish... what matters is which version of Pro you use to create those layout templates aka .pagx files. As long as you create .pagx files from Pro 2.9 or older version, you can use any version of Pro to publish a print service.
But if you create pagx files form 3.0 or above, then you must have 11.0 or above servers. That is because server/enterprise 10.9.1 or older releases can't read them.
I hope this helps.
Teresa_Blader
That does a lot! Thanks!!
Teresa Blader
Olmsted County GIS
by Anonymous User
Not applicable
"As long as you create .pagx files from Pro 2.9 or older version, you can use any version of Pro to publish a print service." Kind of defeats the purpose of upgrading then doesn't it? I have to use 2.9 to create .pagx files, but I can publish from any version. But if I upgrade Pro on my machine to 3.x, I can't create "compatible" .pagx files. So you're forcing people to keep a 2.9 Pro install on a spare/old machine just to create and tweak .pagx files to publish to their 10.9.x  and earlier Enterprise installs. As you've noticed from the comments, this is a nightmare to keep organized.
NourSalamJMT
@MichaelVolz @BenClark @LeviRoberts , and ESRI to please update documentation and bug report: @TomThompsonEsriCA @jln9876
This thread was my saving grace while troubleshooting, so I'm reporting back here. Unlike what the bug BUG-000151319 implies here , using ArcGIS Pro. 3.x to publish to ArcGIS Enterprise 11.1 will not work unless ArcGIS Pro 3.x is installed on the server running ArcGIS Enterprise.
It would also have been a huge time saver if this issue was noted in the documentation I followed here.
Thank you so much.
Nour
CoryBowlin
I can also confirm publishing from 3.x pro to Enterprise 11.1 failed for me. Same reasons. Layout ID and Report ID error. I have no idea what version of pro is running on the Enterprise server, but I’ll try to find out. I honestly didn’t think installing pro on the Enterprise server was a normal practice, but that’s outside my duties.
TanuHoque
@CoryBowlin
what exactly the error message that you are running into?
11.1 server has ArcGIS Pro 3.1 run time.
PS: we had an issue where print service was failing because of incompatibility between the versions of server and Pro installed on the same machine. That is resolved in ArcGIS Enterprise/Server 11.3 release.
CoryBowlin
When publishing a custom print service from Pro 3.2 to Enterprise 11.1 the share as web tool would return critical errors and not allow it to be published. There errors were related to layout ID and report ID. A bug report was submitted and the review team said this was expected behavior due to the “older” version of Enterprise used with a late version of Pro. I have since tested the same workflow using Pro 3.2 and Enterprise 11.3 and it was successful.
