Creating offline maps in Enterprise
2203
10-25-2023 12:43 PM
Katie_Clark
MVP Regular Contributor
I have worked a ton with web maps/feature layers  and configuring them for offline use in ArcGIS Online, but now I am trying to do the same within our Enterprise environment and I'm a little stuck.
Hopefully I'm understanding the terminology correctly...we have parcel data stored on our SDE ("ArcGIS Server feature layer (feature service)") - NOT a hosted feature layer. These services are versioned.
I can access these services in ArcGIS Server Manager and I confirmed the following settings:
Based on what I've read in the documentation, it was my understanding that if a service had sync enabled, then it could be used offline. However, when I add this layer to a web map and then go to the settings page for the web map there is no option to enable it for offline use.
Is there some other step I'm missing to be able to use these layers offline?
Thanks in advance!
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
MarceloMarques
Introduction to distributed data—ArcGIS Pro | Documentation
  • Take a map offline with feature service sync capability
    The sync capability available for ArcGIS Server feature services and hosted feature layers allows you to take feature layers offline in a web map that is configured for offline use. When the data is taken offline, the layers reference a local copy of the data. This allows you to make edits and complete your work without the requirement to be connected to the network. Once network availability is restored, you can upload your local edits.
    When you enable sync on a feature service (feature layer), you can also use it in a distributed collaboration.
    Before you publish an ArcGIS Server feature service to be used offline, you must configure the data to meet offline requirements.
    Feature service replicas
    Feature service replicas provide the mechanism that allows you to synchronize offline feature layers with the source data. The feature service replica receives edits made offline that are subsequently synchronized to the source feature layer. During synchronization, the feature service replica also receives the edits made in the source feature layer and makes them available to the feature layer that was taken offline.
    When you take ArcGIS Server feature service data offline, a feature service replica is always created.
    Tip:
    Depending on the data present in the feature service and the options used when you publish the service, a replica version may also be created and associated with the feature service replica. To learn more about scenarios when a replica version is created, see Prepare data for use in offline feature services.
    FYI: Your data is registered as traditional versioning, therefore read the part of documentation below, you need to work with replica versions in offline workflows.
    Scenario 3: Traditional versions are used to manage multiuser edits
    If your organization requires the use of traditional versions because you use a quality assurance version of the data, you can use the following offline workflows. Each workflow has specific data and publishing sections. Each workflow creates a replica version.
    As with all named versions, you must reconcile and post edits from all the replica versions generated in this scenario with their parent version. See Replica versions in offline workflows for more information.
    For examples of these workflows, see Offline maps and versioned data.
    Note:
    Replica version names are limited to 30 characters. The feature service portion of the name will be truncated to meet this limit.
    FYI: the documentation explains other scenarios as well.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
JuanManuelCruzHerrera
Si quieres trabajar sin tanto problema con la sincronización usa versionado en rama o no uses versionado y usa archivado habilitado. La versión tradicional da bastantes problemas para temas de sincronización no solo por que hay que conciliar al padre sino porque tienes que tener bastante cuidado por como creas la Base de datos y mirar bien lo que te puso @MarceloMarques porque cualquier pequeño paso que te saltes o algo que no hayas tenido en cuenta te va a dar problemas con el sincronizado siempre.
