Core series vs Xeon series > Which is best for Batch Build Statistics and Batch Build Pyramids?
369
04-08-2025 09:09 AM
BillFox
MVP Notable Contributor
DavidSolari
MVP Regular Contributor
Assuming you don't care about extra PCI lanes, ECC memory etc. a high-end core series is usually better than any workstation class Xeon in Pro due to the inevitable single thread bottlenecks. That said, these 2 tools might actually use threads efficiently so it's hard to tell without proper benchmarking. If you have the budget and time then build both, run your standard workflows on both and refund whatever loses. You should also consider AMD's standard chips over Intel, the high-end Core chips have a bad habit of destroying themselves and the X3D chips obliterate anything that's memory bottlenecked (i.e. almost everything your computer does).
BillFox
some rough results:
batch calc stats twice as fast on xeon
batch build pyramids twice as fast on i9
