I have an SDE database that is registered in the Data Store of my server:
I reference this database connection in the python script (the geoprocessing service) as this:
db_con <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'Database Connections\HbMonitoringTest_nbcidb_HabitatTestWriter.sde'</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
I check to see if the connection evaluates to true, but it doesn't and I'm not sure why.
<SPAN class="keyword token">if</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Exists<SPAN class="punctuation token">(</SPAN>db_con<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"your db connection worked"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">:</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"your db connection sucks"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Is this not the appropriate way to reference database connections in a geoprocessing service? Do I need to store the .sde connection file in a local folder on the server and connect using that instead? I have noticed int he v101 folder on the server, that the python script it contains did not replace "Database Connections" with the ESRI generated variable arcpy.env.packageWorkspace. Might that have something to do with it?
