Clone Hosted Feature Service in Portal for ArcGis
4985
03-31-2015 11:38 AM
KarstenRank
Hello,
is it possible to clone a Hosted Feature Service in Portal for ArcGis and give the "new" one different permissions (e.g. not editable) then the original service?
Thanks for your help and any ideas,
Karsten
DerekLaw
Esri Esteemed Contributor
Hi Karsten,
This is not a supported workflow in Portal for ArcGIS at this time. Workaround: I suppose you could re-publish the original source data as a new, separate hosted feature service (immediately after you publish the original one) with a different name to support this workflow.
Hope this helps,
RebeccaStrauch__GISP
​(bump ... Sorry I don't have an answer)
it may help to move this to Portal for ArcGIS   since it may get more users that use Portal.
you should see the option to move the thread in the right column.  More info Moving Content
DerekLaw
Hi Karsten,
Hope this helps,
KarstenRank
Hi Derek,
I also found this way. Would it be supported in future? We want to store some sample feature service and clone them in the Portal.
Karsten
DerekLaw
Hi Karsten,
At this time there are no plans to implement this functionality. Please submit your Portal for ArcGIS enhancement request here:
Esri Arcgis Ideas | Ideas Submission Portal
Hope this helps,
AndresCastillo
