Changing the Size of ArcGIS WebMap Pop-Up Panel
666
05-16-2024 04:40 AM
AkhilRajT
I hope you all are doing well!
I am currently working on a project using ArcGIS WebMap in Enterprise 11.2, and I have encountered a challenge that I believe some of you might have faced as well. Specifically, I am looking to change the size of the pop-up panel, particularly its width. As of now, it appears that there is no straightforward option to adjust the pop-up panel size from its default settings.
Has anyone found a workaround or a method to customize the size of the pop-up panel? Any tips, code snippets, or guidance on how to achieve this would be greatly appreciated.
Thank you in advance for your help!
Regards,
Akhil Raj T
