Change input parameters of GeoProcessing service in ArcGIS 10.1
412
09-14-2013 11:37 PM
AmmarAssem1
I am Using ArcGIS 10.1, I wish to publish GeoProcessing Service I open model in ArcMap, open results window, right click in map and
share as GeoProcessing service but the problem GeoProcssing service set input parameters as I using in ArcMap.
for example i using select tool in model when I open this model in ArcMap I use shape file with polygon features as input when I publish model input parameter in service set as geometry type : polygon i need to change this type to any type.
Thanks in advance.
