Cannot delete portal item after upgrade to 10.6.1
6235
12
05-01-2019 06:49 PM
ClintonBallandis1
I've recently upgraded from Enterprise 10.5 to 10.6.1. When I try and run the webgisdr the Portal backup is failing.
The backup is failing because portal can’t export  an item Export of the Portal repository failed. C:\arcgisportal\content\items\e5516d3106674d528b62b01621bce864
It is interesting that the 10.5 webgisdr backup ran without any issues suggesting that the orphaned items didn't exist ?
If I search for the item e5516d3106674d528b62b01621bce864 in the contents folder on the Portal server no files are returned. However if I search in the Portal itself through I can find the item. If I click on the item to try an access the item details to delete it nothing is returned.
I've tried going into the rest/sharing directory and into my content. I can see the items I want to list however when I select one to delete  and internal server error 500 is returned.
I've also tried re indexing the portal.
Any help would be appreciated.
Clinton
ClintonBallandis1
Hi all,
I managed to get this resolved via a support call with ESRI. There were a number of possibilities to work through.
ClintonBallandis1
Hi all,
DevonBise
Could you provide some details on what worked for you?
ClintonBallandis1
This was quite a long process to resolve. ESRI tech support gave me a number of senarios that I had to work through  before I managed to delete the orphaned items. As this was not a standard fix I would recommend contacting ESRI support directly.
Clinton
BillFox
MVP Notable Contributor
#BUG-000122635 Update the error message when failing to reach an ArcGIS Server service from Portal for ArcGIS.
  • Portal fails to delete several different items in content folder
ClintonBallandis1
Hi Bill,
Great to see this error has been fixed in 10.8. Thanks, for posting.
Clinton
ScottLarkin
Hi Bill,
Any chance we can get the resolution to Clinton's issue for removing the portal items as I am experiencing the same issue at version 10.6.1
Scott
BillFox
Is this the error you are getting with "supposedly orphaned items"?
I just received clarification that the bug # is just to provide better error message, not to fix this promlem.
This link has steps to successfully delete portal items. Even newly added - non orphaned ones.
I have elevated the issue with Esri support lead.
Error: Unable to reach the server where the service is. Consider using calling deleteItem with optio...
Error: Unable to reach the server where the service is. Consider using calling deleteItem with options = { 'force' : true } if the server won't be available anymore
ScottLarkin
Hi Bill,
The error I get in Portal is "Failed to determine if item can be deleted
Portal Error
Also when I go to the following URL - https://<portalURL>//sharing/rest/content/users/<username> and try to delete, I get an error "Unable to delete item", even with the Force deletion checked.
Delete serviceDelete Service Error
BillFox
Is that as a portal admin or publisher?
