Can't Publish Geodata service
2122
08-28-2013 06:16 AM
ShaningYu
Honored Contributor
Following the procedure from ESRI: http://resources.arcgis.com/en/help/main/10.1/index.html#/Publishing_a_geodata_service/0154000003780..., I tried to publish an Oracle SDE Geodatabase.  I went through the steps suing the Service Editor wizard.   After I click the Analyze button, the Prepare window popped out and showed 0 Errors and 0 Warnings.  Then, I clicked the Publish button in the Service Editor wizard, but I received the error message: You must fix your analysis errors before continuing.
I got confused and don't know what analysis error(s) I have.  Thanks if you can share your experience.
ShaningYu
Honored Contributor
From my college, I learned the GDB would be in Re-starting.  I believe that was the reason I could not publish the Geodata service since it was down.
ShaningYu
Honored Contributor
ShaningYu
Honored Contributor
In my previous threat, it was found that the SDE DB was down.  After re-starting, I could continue the publishing.  However, I got a new High Severity error: Geodatabase is not registered with the server.  I going to do the GDB registration and then continue.
