Can't connect to oracle pluggable database (18c)
1496
06-17-2020 06:53 AM
DanielSotreanu
Hi Guys,
Is there any specific trick to create a connection from ArcCatalog to a pluggable 18c database?
The database is installed on Windows Server 2019 and I am able to connect to it's $CDB container from ArcCatalog. SDE schema is created on a pluggable container and I can't login no matter the connection info I use:
- tns name (XEPDB1)
- full connection string (HOSTNAME:1521/XEPDB1)
Fail to connect to specified server. Do you want to continue?
Bad login user.
ArcCatalog is hosted on another Windows Server machine (same network).
I am able to login with SQLPlus from ArcCatalog machine, including to the pluggable container.
I have both 32/64bits clients.
I do not see anything in the log locations (e.g. C:\Users\%user_profile%\AppData\Local\Temp)
Thank you,
Daniel
Bud
Esteemed Contributor
Did you find a solution?
I have the same problem: Create database user in Oracle 18c XE via ArcGIS Pro
Bud
I figured out my problem.
My TNS wasn't set up correctly. I had to add a TNS entry for XEPDB1. (Previously, it only had an entry for XE.)
 XEPDB1 =
  (DESCRIPTION =
    (ADDRESS = (PROTOCOL = TCP)(HOST = 192.168.1.3)(PORT = 1521))
    (CONNECT_DATA =
      (SERVICE_NAME = XEPDB1)
Now, I'm able to connect to XEPDB1 in an ArcGIS Pro database connection (reminder: restart ArcGIS Pro after editing tnsnames.ora):
Likewise, I'm now able to create a new user using the Create Database User geoprocessing tool, because I'm connected to the XEPDB1 PDB:
Bud
@MarceloMarques said:
ArcGIS Pro use for "Instance" the Oracle easy connect syntax "192.168.1.3:1521/XEPDB1"
You can test this via Oracle SQL Plus first, if able to connect with SQL Plus then ArcGIS Pro will be able as well.
Connect to Oracle from ArcGIS—ArcGIS Pro | Documentation
https://community.esri.com/t5/data-management-questions/create-database-user-in-oracle-18c-xe-via-ar...
I'm not sure if that helps you with your problem or not.
