Can ArcGIS Desktop Client 10 connect to ArcGIS 10.1 server services?
1775
08-08-2012 10:55 AM
SteveMcCarthy
BubbaHey
Yes, assuming you mean something like connecting via ArcCatalog. However, you will need to make an administrative connection. See:  http://resources.arcgis.com/en/help/main/10.1/index.html#//0154000003qn000000
BubbaHey
Actually I may be wrong about that. I know there are issues if using ArcSDE where you need to upgrade the database. But you should be able to connect from 10.0 to 10.1 server
by Anonymous User
Not applicable
Original User: bubbahey25
Yes, I was wrong, can't make an Admin connection in 10.0 to 10.1 but can make a "Use GIS Services" connection
