Build points from X, Y in Arcgis Enterprise
1621
10-16-2020 08:15 PM
SoratoSouza_e_Silva
I have a table hosted on the Portal, but this table has two fields X and Y, is it possible to create points from these fields in the Map Viewer? Or publish directly from ArcGIS PRO building these points at the time of publication?
Thank´s
Sorato
Tags (1)
EduardoFernandez1
Hello Sorato
In the map viewer, there is no standard tool to create points from a table. At the point when you add the table into ArcGIS Online or ArcGIS Enterprise, you can create a hosted feature layer and points from X and Y stored in this tabular item. https://doc.arcgis.com/en/arcgis-online/manage-data/publish-features.htm
In Pro you can create an XY event layer from your table which results in a new feature class with point features which you add to your map for publishing: https://pro.arcgis.com/en/pro-app/tool-reference/data-management/make-xy-event-layer.htm
Here are two good tutorials more generally on this topic
Create points from a table—ArcGIS Pro | Documentation
Create points on a map—ArcGIS Pro | Documentation
Cheers Ed
EduardoFernandez1
Hello Sorato
Cheers Ed
SoratoSouza_e_Silva
Thank´s
