Azure backup of data store
973
05-22-2019 12:13 PM
JoshHevenor1
I'm setting up some backups of a spatiotemporal big data store (v10.6.1) and would like to push them into an azure blob.  I'm reading this doc:
https://enterprise.arcgis.com/en/portal/latest/administer/linux/data-store-utility-reference.htm#ESR...
I'm confused as to what the --location parameters should be.  The example lists
--location type=azure;
location=mybackups;
name=secondrelloc;
username=myazureaccountlogin;
password=zpw4myazureaccount
So if I have a storage account: https://samplesa.file.core.windows.net/ with a container somecontainer, how does that map to what's being asked?
For the username and password, what's expected?  I have an account I created all the VMs with (not using that), and I could grant access to some AzureAD account.  I more expected to pass in a key or SAS.
Any advice is appreciated.
ThomasColson1
This took me forever to figure out. ArcGIS Data Store utility reference—Portal for ArcGIS | Documentation for ArcGIS Enterprise contains command examples.
What worked for me was: configurebackuplocation --operation register --store tileCache --location "type=azure;location=[blob container name];name=DEV_STDS_BU;username=[azure storage account name];password=[secret access key]"
Note you need a separate container for each datastore
