Hi - running ArcGIS Pro 3.2 on Citrix - everything's fine, not usually noticeably slow, but click on preview in the attributes table for the graph? Nope. Create a graph? Yep. Can you see it? Nope. A sea of blank tabs faces you with this software combo... haven't used it except at a basic level, but can't get the visualise stats to work, either. Just returns a blank tab. Right clicking on the layer in the Contents pane and selecting Create Chart works just fine but returns a blank tab with all filter options etc. greyed out. Nothing to select.
HiWe are currently looking to deploy ArcGIS on Citrix across our Authority. Does anybody have any experience of running ArcGIS on Citrix as opposed to Desktop clients? We are especially interested in known issues/ performance and optimum settings for improving speed, which initial testing has shown to be very slow. We will be running on a minimum version of 9.3, but possibly 10.Any help or advise would be much appreciated!Thanks
I thought it was worth noting in this thread a reference to this new article:FAQ: What are the requirements for ArcGIS Desktop support on Citrix?http://support.esri.com/en/knowledgebase/techarticles/detail/39489
If anyone is experiencing visual artifacts with ArcGIS 10.x (or prior release) on Citrix, reducing Application Color Depth to 16-bit color seems to address a number of these issues. (Citrix Access Management Console > Farm > Application > ArcMap > Properties > Advanced > Appearance > Colors > Set to 16-bit)Most notably, recently we found that Citrix clients running ArcGIS 10.0 / XenApp 4.x / Windows 2003 Server are unable to render the "ArcGIS Online" browser from within ArcMap. Reducing ArcMap color depth to 16-bit addresses this issue.* The issue does not surface with ArcGIS Desktop 10.0 / XenApp 5.x / Windows 2008 Server.I'll continue to post these "tips" as we run across them.
ESRI Support asked to me to test that as well. When a user used RDP to remote in, the peformance was 'normal'. When I run Task Manager, I only see my own apps running. We only have 10 users (clients) on a 16 CPU and 12GB Ram server (new since June 2010). The CPU usage rarely goes beyond 10%, memory usage is usually around 5GB. Performance was also extremely slow when only 1 user (administrator) was logged on. I don't think we are overwhelming our Citrix server...Thanks for your feedback! Any other suggestions to try?Julie
Mark, We are having the exact same issue where we get the "unable to open...", but is we are admin or logged into the desktop the image (tif) opens successfully. Did you ever find what caused this problem?Thanks,Scott BarkerAlabama Gas
instead of pushing them back to the client, I would like to push them to the user's "home" drive which is on the local network with the Citrix server. Does this special folder redirection accomplish that? I'd also like to redirect the cache folder to their home drive as well.
You can probably get what you are looking for by enabling "Special Folder Redirection," a Citrix concept will push the GDBs created for each profile back to the client (http://support.citrix.com/proddocs/index.jsp?topic=/web-interface-hardwick/wi-enable-special-folder-redirection-gransden.html). BUT....be advised that enabling "Special Folder Redirection" within Citrix results in a considerable performance loss from the client side as data that normally would be locally available to the Citrix server now has to traverse the LAN/WAN link between client and server. (Among a host of other complications).
Though I earlier in this thread stated that we have experienced little to no problems in using the Citrix Deployment method for ArcGIS, there have been a few little pesky items. One of which follows:When I thry to author and serve out a map (either through ArcServer or Publisher) using ArcGIS through the Citrix connection, the data links break and the end user (web or ArcReader) sees only the data holder in the TOC along with the broken link symbol. Same map is then opened in ArcGIS on a local install, the data sources reset to exactly what they were before(but resetting is required), then the maps as served out (via ArcServer or Publisher) contain active links and all is well.After researching this a bit, I did discover that when looking at the data sources for the .MXD file in ArcCatalog, the connection file found on the \Application Data\ESRI\ArcCatalog\[connection].sde path was set to where the IT folks are preserving the profile information that Citrix uses when a user is logging in. (see attached).The data source file is shown on another computer - in this case:\\rcg-file1\appdata$\jearmstrong\Application Data\ESRI\ArcCatalog\SdeConnect@richmond_vector.sde - this is where the user profiles are being storedNormally this connection would be "Database Connections\SdeConnect@richmond_vector.sde" which seems to resolve to C:\Documents and Settings\[username]\Application Data\ESRI\ArcCatalog\Admin@richmond_vector.sde.Is there a way to set this data connection path to allow data in a map service authored through the Citrix deployment of ArcGIS to be viewable by the end users? I realize there is a manual workaround, but that kind of defeats the purpose of running the GIS through Citrix. I hope somebody can shed some light on this issue.thanksJames ArmstrongRichmond County, North CarolinaGIS
