I've been using ArcPro for everything for a few years, but it seems like we still need ArcCatalog to view the map cache status.
Is this planned to be in ArcPro sometime? When can we get rid of ArcMap completely?
(I'm not upgrading Pro until ESRI fix the display XY bug in 2.7 anyway)
Edit service caching properties in Manager—ArcGIS Server | Documentation for ArcGIS Enterprise
Note:
While many settings for cache management and generation are available in ArcGIS Server Manager, those dependent on geoprocessing tools are not available. To modify these, you can access cache properties in ArcMap. In addition, some settings cannot be modified after publishing, and appear as read-only in Manager."
