ArcGis Server Manager
1837
6
06-26-2019 03:08 PM
FernandoVasquez
New Contributor II
Hi everyone, can you help me?
when I wanted to install ArcGis Server Manager, i have this problem:
"Error there was an error creating your initial administrator account
index service configuration failed
For more information, please view the log located in the content directory specified during setup (C:\sites\srcgisportal\logs)"
Do you know what is the possible solution or something like that ???
Attached the image
Thank yo so much
DerekLaw
Esri Esteemed Contributor
Hi Fernando,
What release of ArcGIS Enterprise are you trying to install?
The screenshot indicates that you're trying to setup a Portal for ArcGIS site, not ArcGIS Server Manager - can you please confirm?
Have you looked at the contents of the log file? What does it say? Can you please post the contents of the log?
Hope this helps,
FernandoVasquez
New Contributor II
Hi Derek
About your questions:
It´s 10.7
 <Msg time="2019-06-27T14:46:56,165" type="SEVERE" code="110506" source="Data Store" process="3436" thread="60" methodName="" Attempt to configure data store failed. Attempt to configure data store failed.. Extended error message: Failed to configure spatiotemporal big data store.. Extended error message: Failed to start spatiotemporal big data store machine.. Extended error message: Failed to start spatiotemporal big data store machine.</Msg>
<Msg time="2019-06-27T14:46:56,165" type="SEVERE" code="218028" source="Portal Admin" process="3436" thread="1" methodName="" Index Service configuration failed.</Msg>
This is the contents of the log
Thank you for your support
DerekLaw
Hi Fernando,
I suggest you verify that you've met the system requirements for the ArcGIS Data Store:
ArcGIS Data Store 10.7.x system requirements—ArcGIS Enterprise system requirements | ArcGIS Enterpri...
For example, for the spatiotemporal big data store you need 16 GB free memory.
Hope this helps,
JonathanQuinn
Esri Notable Contributor
Are you on a one core machine? If so, The internal index service will fail to start:
BUG-000122935 - Unable to create a site or initial administrator account for Portal for ArcGIS 10.7 on a single core machine.
If you have more than one core, take a look at the logs under C:\Program Files\ArcGIS\Portal\framework\runtime\ds\usr\logs\<machine>\elasticlog
Su_MayOo
Hi Jonathan,
I am having the same error message as above while I am creating ArcGIS Portal site and creating ArcGIS portal administrator account. But I am using Linux OS. The BUG is recorded as Windows platform.
May I know if my issue is also related to this bug BUG-000122935: Unable to create a site or initial administrator acc..  ?
We currently have 4 CPU and 1 core per socket. Do we need to have multiple core in each CPU? eg., 4 Cores per CPU? Can we also have like 2 CPU with 2 cores each? Because minimum requirement for Portal server is 4 cores for 100 concurrent users. Please advise.
I am using below versions of ArcGIS, OS and current configuration of the server.
ArcGIS version: ArcGIS Portal 10.7.1
OS version : Red Hat Enterprise Linux Server 7.6 (Maipo)
Below is the error message in the log file.
Thanks in advance,
Su May
WilliamCraft
MVP Regular Contributor
Adding additional cores to our single-core virtual machines resolved this error for us as Jonathan Quinn suggests via the aforementioned bug.
