ArcGIS Server Manager - Wher is the checkbox for SOE?
454
10-01-2013 10:01 AM
ShaningYu
In ESRI Help: http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#//000100000nvs000000, How to enable a server object extension on a service, it mentions
3. Click the Capabilities tab.
4. Select the check box next to the SOE you want to enable.
I followed the procedure and checked a service, but could not find such a checkbox.  Followed the procedure to check Catalog's ArcGIS Server tree, and no checkbox was observed.
Please hint me if you know.  Thanks.
ShaningYu
The info in ESRI's help is somehow not clear.  After .soe is added, there will be an additional box in a service's capabilities (like KML, etc.) .  Hopefully, ESRI help can provide clearer statement in some of its help topics.
ShaningYu
Just found that I should register the SpatialQuerySOE.dll.
ShaningYu
However, I searched it through my CPU, but the SpatialQuerySOE.dll not found.  Now my Q are that
1) For ArcGIS Server 10.1, how can the SOE be enabled?
2) Is the SpatialQuerySOE.dll still be required?
Thanks.
ShaningYu
