ArcGIS Server: Can temporary files be deleted from arcgis Local AppData folder?
7952
10
11-27-2018 07:05 AM
FrancescoTonini2
I have an ArcGIS Server 10.4.1 deployed on an AWS EC2 instance with Windows Server 2012 R2 on it.
I noticed the C:/ drive attached to the instance is quickly running out of space and I was able to identify the source of it. Under C:/Users/arcgis/AppData/Local/Temp I have several big files that were generated at different points in time.
My question is: can I safely remove these files manually to clean up space without compromising the functionality of several web services published and hosted on that same machine?
stevecater1
We have 132 GB of .sde, .gdb folders, tmp-ags-export-* folders in the C:\Users\serviceaccount\AppData\Local\Temp   location.  Portal, AGS and Datastore single deployment 10.9.1. So obviously in this case nothing is being deleted by the application. Esri Case #03731334
