ArcGIS Server, ArcGIS Desktop and ArcGIS Pro Version Compatibility
1841
5
04-12-2022 11:45 AM
EmilyL
Hello. I couldn't find a compatibility matrix about this.  But I'm wondering if I currently have ArcGIS Server (ArcGIS Enterprise) 10.6.1, can I still upgrade to the ArcGIS Desktop to 10.8.2 and ArcGIS Pro to 2.9 without upgrading ArcGIS Server?  Thank you!
BillFox
MVP Frequent Contributor
Depending on your environment you might need to work in order similar to the list below and squeeze in some TLS 1.2, HSTS, SSL, etc. along the way.
1st upgrade the os tier from say 2012 to 2019
2nd upgrade SQL Server(s) from 2014 to 2019
3rd Enterprise from 10.6.1 to 10.9.1
4th Desktop & Pro.
And maybe have to recreate some web services, webmaps, apps, etc.
BillFox
You will need to sketch out a few check-off grids for SQL Server/Oracle..., ODBC Clients, Windows OS (server and desktop), .NET, Enterprise, etc.
BillFox
4th Desktop & Pro.
EmilyL
Thank you Bill very much for your reply.  Very appreciate it!
Does it mean we must first upgrade the server machine from Windows Server 2012 to 2019 in order to upgrade desktop and Pro?  We currently have the following:
Server Version: 10.4.1.5686
     Operating System: amd64 Windows Server 2012 6.2
     Available processor cores: 8
Thanks again!
Emily
BillFox
It all depends on your entire setup.
Your check-off grids will reveal to proper workflow.
EmilyL
Thank you Bill!
