ArcGIS Server 10.7.1: Starting a service ends up with “Error handling service request: Failed to register the activation group” error,
1889
12-06-2020 01:09 PM
JamalNUMAN
Legendary Contributor
I couldn’t figure out why Starting a service ends up with “Error handling service request: Failed to register the activation group” error
What might be the issue here?
Jamal Numan
DavidPike
MVP Frequent Contributor
I'm guessing you've tried restarting ArcGIS Server?
JamalNUMAN
Thank you guys for the help.
  • The ArcGIS Server windows service is running
  • The logs doesn’t provide siffeicnt information to fix the issue
Jamal Numan
JoshuaBixby
As I suggested earlier, change the logging level to DEBUG to get more information.  If you are using default logging, then you are only capturing WARNING and ERROR messages, which aren't always helpful when troubleshooting an issue with a service not starting.
JoshuaBixby
Have you turned on debugging level for logging and looked at the logs?
