ArcGIS Server 10.7.1: How to determine the number of CPU Cores and RAM size of a server machine that can support up to 250 concurrent users for a web mapping application?
2479
08-28-2020 12:47 AM
JamalNUMAN
Legendary Contributor
I couldn’t figure out how to determine the number of CPU Cores and RAM size of a server machine that can support up to 250 concurrent users for a web mapping application that consumes GIS web service published in the server machine.
The documentation recommends trail and error approach in order to decide on the optimal server machine resources that should cover the need (load).
In general, for design, we need to calculate the load (traffic) based on which resources are specified. Which mathematical approach can be of help in this case?
Jamal Numan
George_Thompson
Esri Notable Contributor
I would take a look here to develop the capacity planning - Capacity Planning Tool - GIS Wiki | The GIS Encyclopedia
--- George T.
JamalNUMAN
The Platform Capacity Calculator confirms that the number of concurrent users depends on CPU, data (mdf, gdb, shp, etc.), ArcGIS Server services (mxd, ,msd, wms, mosaic), operating system (winows, linux, ect.), and platform (physical, VM, etc.),
Jamal Numan
IhabHassan
Hi Jamal
I am using the CP analysis tool for estimating the HW specs for a new ArcGIS Enterprise deployment, and I wonder if you can guide me on how I can find the calculated RAM utilization for the architecture platforms used in the analysis.
Ihab
Regards
Ihab
JamalNUMAN
Hi Ihab,
Unfortunately, there is no direct relation between the load (number of requests) and the resources (Cores\RAM) which makes it a bit challenging to find a good match between them (load and resources).
Best
Jamal
Jamal Numan
