ArcGIS Server 10.1 SP1 - Geoprocessing service - Shape field not visible
795
09-23-2013 05:41 AM
PetraStrbenac
Hi everyone, I am having problems with geoprocessing services published with ArcGIS for Server 10.1 (SP 1) for .NET because Shape field (from user geometry input - GPFeatureRecordSetLayer) is not visible and I require this for the script to run successfully. I have noticed this on all of my geoprocessing services that have user geometry input (point, line or polygon). I also noticed this before and after the installation of SP. Geometry input uses schema from a feature class that has Shape field set to visible. Shape field is also visible in the process of preparation of gp service for publishing (on Tabs related to service parameters), but as soon as I publish the service, the Shape field is no longer visible. Does anyone have any idea why this is happening, could this be a bug?? Any feedback would be greatly appreciated!
Petra
