ArcGIS Server 10.1 hitting SDE 9.2 on another server
1189
10-03-2012 12:25 PM
Gregde_Bruin
We have ArcGIS server 10.1 running on a new server.  We would like to publish a map service that reads from a 9.2 SDE (oracle) geodatabase on another older server.  Is this possible?  Anything special I need to do to make it happen?
DerekLaw
Esri Esteemed Contributor
Hi Greg,
You'll need ArcGIS for Desktop 10.1 to publish to ArcGIS for Server 10.1.
FYI: 10.1 clients are not able to connect to pre-9.3 ArcSDE geodatabases: Client and geodatabase compatibility
The workflow you describe is not possible.
Hope this helps,
DerekLaw
Hi Greg,
Hope this helps,
Gregde_Bruin
Not the answer I was hoping for but still valuable.  Thanks very much.
HalilSiddique
Mine does.....:confused:
lunlee
me,too.
I successfully publish Spatial Data from ArcSDE 9.2 through ArcGIS Server 10.1;
My Web Application works with ArcGIS Server 10.1 services very well,just like services in ArcGIS Server 10.
I haven't got any error or warning from ArcMap when I was publishing services to ArcGIS Server 10.1.
:confused:Is there any potential problem?
DerekLaw
Halil and Lun,
Regarding the ability to connect from a 10.1 client to a 9.2 ArcSDE geodatabase data source: we did not block connections to 9.2 geodatabases, but it is an unsupported configuration and has not been tested/certified.
Hope this helps,
