ArcGIS Server 10.0 URLs to connect from ArcCatalog
3617
14
02-13-2021 11:14 AM
LanceCole
MVP Alum
Does anyone remember the URLs to connect to ArcGIS Server 10.0 from ArcCatalog to administer the data?
We have an old ArcGIS Server VM image that we have spun up to try and recover some data that was lost years ago.  We have the server up and can access the ArcGIS Server Manager web interface but have been unable to connect via ArcCatalog.  Honestly, none of us can remember the connection URLs.
There was a big change between 10.0 and 10.1 and the sites do not use ports.  We were able to access the server to "Use GIS services" in ArcCatalog 10.8.1 using http://gisserver.domain.com/arcgis/services but can only view the data and not administer the GIS server or data in any way from ArcCatalog.
We spent about two hours with ESRI tech support yesterday trying to get the installed ArcCatalog 10.0 up and running, which has all the GIS Server links saved.  We were not successful as 10.0 is just not supported any longer and license files are just not available.  We have been trying to access using a new version of ArcCatalog (10.8.1) with only a small glimmer of hope.
Any ideas or suggestions would be appreciated.
LanceCole
MVP Alum
Not necessarily ArcInfo/advanced, we just happen to have that version installed on the old VM, you cannot use a version of ArcGIS Desktop newer than 10.0 to access ArcGIS Server 10.0 via an administrative connection. Below is the reference from https://resources.arcgis.com/en/help/.
JoshuaBixby
In all likelihood, that note was added when 10.0 first came out, and it was meant to say you have to use 10.0 and not earlier versions.  What happens when you try to connect a newer client to the 10.0 server machine?
LanceCole
MVP Alum
We found that note in the 10.1 or 10.2 documentation.  Using 10.8.1 we are able to make "user" connections to the ArcGIS Server but cannot create "publish" or "administrator" connections via ArcCatalog.  We also installed a copy of ArcGIS Desktop 10.2 and tried that as well, with the same results.  The credentials we are using are able to log onto the ArcGIS Server Manager web interface and works with the "user" connection, so it should not be a permissions issue.  The tools we would like to run against the server are not available with just a "user" logon.  It needs to be an "administrator" logon.
The connection error we are getting is noted below which made us question the URL and the reason for our original post.  After finding the archived help documents, we believe we are using the correct URLs to connect and the issue is most likely newer versions of ArcGIS Desktop cannot be used.
LanceCole
MVP Alum
Your post made me question if we had interpreted the ESRI's note correctly, so I went down that rabbit hole again.  Unfortunately, we found the same information but this time without question.  Only ArcGIS Desktop 10.0 can be used to manage ArcGIS Server 10.0.
This is from - ArcGIS Help 10.2, 10.2.1, and 10.2.2 as was the previous note found in another section.
LanceCole
MVP Alum
ESRI Customer Support to the rescue.  ESRI was able to help setup a new license server that would support ArcGIS Desktop 10.0.  We were able to access the ArcGIS Server from ArcCatalog and are in the process of exporting the Image Cache files.  Once those files are safe we are going to dig around and find the other data that is visible from the hosted services.
The connection string was as we thought http://gisserver.domain.com/arcgis/services.  The issue was ArcGIS Server 10.0 can only have an administration connection created using ArcGIS Desktop 10.0.  No other versions will work.
