Hi Guys,
I'm getting some trobles with ArcGIS Geoevent 10.7.1. It's looks a problem on the Geoevent Gateway service. When I'm triyng to access the geoevent manager https://XXXXXma01:6143/geoevent/manager/login.html?url=index.html, the follow message is shown:
ArcGIS GeoEvent Server is waiting for a connection to the Zookeeper. If this takes too long, contact System Administrator to make sure Gateway is properly running.
I'm also was looking for log files, and got thoses messages bellow in the file X:\ArcGIS\Server\Geoevent\gateway\log\gateway.log
2019-10-11 20:19:18,009 [myid:POCSMA01:4181] - INFO [WrapperSimpleAppMain-SendThread(POCSMA01:4181):ClientCnxn$SendThread@1106] - Opening socket connection to server POCSMA01/192.168.xyz.xyz:4181. Will not attempt to authenticate using SASL (unknown error)
2019-10-11 20:19:18,500 [myid:POCSMA01:4181] - INFO [Thread-5-SendThread(POCSMA01:4181):ClientCnxn$SendThread@1106] - Opening socket connection to server POCSMA01/fe80:0:0:0:89e:cda:3f57:953c:4181. Will not attempt to authenticate using SASL (unknown error)
2019-10-11 20:19:19,009 [myid:POCSMA01:4181] - INFO [WrapperSimpleAppMain-SendThread(POCSMA01:4181):ClientCnxn$SendThread@1235] - Socket error occurred: POCSMA01/192.168.xyz.xyz:4181: Connection refused: no further information
2019-10-11 20:19:19,109 [myid:POCSMA01:4181] - INFO [WrapperSimpleAppMain-SendThread(POCSMA01:4181):ClientCnxn$SendThread@1106] - Opening socket connection to server POCSMA01/fe80:0:0:0:89e:cda:3f57:953c:4181. Will not attempt to authenticate using SASL (unknown error)
2019-10-11 20:19:19,502 [myid:POCSMA01:4181] - INFO [Thread-5-SendThread(POCSMA01:4181):ClientCnxn$SendThread@1235] - Socket error occurred: POCSMA01/fe80:0:0:0:89e:cda:3f57:953c:4181: Connection refused: no further information
2019-10-11 20:19:19,602 [myid:POCSMA01:4181] - INFO [Thread-5-SendThread(POCSMA01:4181):ClientCnxn$SendThread@1106] - Opening socket connection to server POCSMA01/2001:0:34f1:8072:89e:cda:3f57:953c:4181. Will not attempt to authenticate using SASL (unknown error)
2019-10-11 20:19:20,109 [myid:POCSMA01:4181] - INFO [WrapperSimpleAppMain-SendThread(POCSMA01:4181):ClientCnxn$SendThread@1235] - Socket error occurred: POCSMA01/fe80:0:0:0:89e:cda:3f57:953c:4181: Connection refused: no further information
Does anyone had this problem?
The environment is:
AWS Instance r4.xlarge Windows Server 2016
ArcGIS Enterprise 10.7.1
